2" lift shackle dimensions
Hey, i have seen shackles here and there and found ones on ebay for $100 (i am in canada) i will order them but i would like to know the exact dimensions so i can make my own.
i read 8" long for 2" lift... what about hole positioning, width, etc
i want 2-2.25" lift in the back
thanks
thanks
I would suggest buying some universal shackles form most autoparts stores (for about $20). If you wish to fab your own, just check the fit of the universals, use them as a template and build your own or improve on the unis). Can't tell you how they will hold up (as is) though.
I have not done this, but I will be picking up a set of the universals for a quick 2" lift this weekend. If all goes well, I will try to post up a picture or two of how they go on.
Also try www.synergyoffroad.com for a set built to fit your Blazer specifically.
Hope that helps.
**EDIT** Looks like Synergy and 3 Leaf Fab are both out of stock at this time. Might have to go the uni route. Good Luck.
Hope that helps.
I just installed a set of synergey 1.5 inch lift shackles and it as the best money I have spent on my blazer yet. They are a heavy duty shackle that are way better built then anything that came from the factory. They were also out of stock when I ordered mine but it was well worth the wait. Thank you Synergy
how long were the shackles to get 1.5 lift?
Just use the stock measurements & increase the distance between center or top of the bolt holes, bottom, doesn't matter, just measure from the same points of refference & add 1.5"
I have pics of the ones I made in my profile (I think). I just added 2" to the stock distance.
here they are https://blazerforum.com/forum/members/rottidog-12089-albums-garage-cb-gf-calls-gag-cranberry-blazer-1128/
I believe mine are 10", 8" bolt centers. 3" from inside to inside.
don't remember the drill bit I used for mine. use a minimum or 1/4"x2". i used 3/8"x2" flat bar
I drilled my holes 1" from top/bottom, welded in a cross brace(just in case, so they don't fold over) drill press is handy, I clamped all mine together and drilled all 4 pieces at once to make sure they were the same. I then bolted them together and used the bench grinder to round the corners, but if you don't have a good grinder it will take forever to do them all at once.
you need ~4' of flatbar to make a set of shackles.
just measure yours and add 4" to gain roughly 2" lift. because you are only lifting one side of the leaf spring, every 2" of increased shackle length will only give you a hair under an inch
hope this helps
hope this helps
you got that right i just spent 6 hrs changing my shackles and only got a inch of lift not the 2 inches i was hoping for so im thinking the addleaf maybe a 2inch spring will get me sittin lvl
and dont forget new bushings and bolts for those shackles your factory will be hard to get off and you have to cut a bolt or 2 and you may ruin a bushing
if you are doing add-a-leaf as well (or over 2" shackles) your shocks will pretty much be maxed out. 1/2 ton 4x4 rear shocks are what i used... ~3-4" longer, and bolt right in.
here they are https://blazerforum.com/forum/album.php?albumid=1128
