2002 2wd
hello,
i have a 2002 2wd ls and i was wantin to know your guys opinion/help on lifting it. any suggestions? Thanks! |
I'd recommend a body lift to start with.. see how you like it. A lot of the guys here run Performance Accessories Body Lifts, they're cheap and you can most likely install it yourself. If you decide you want bigger/better (and more expensive) things check out some suspension lifts.
Are you definitly set on lifting your 2wd? If I was looking for something to lift i would lean more towards a 4wd truck
if u want to go higher of a lift, u can do a spindle converson from the same year S-10 pickup. and i'm doing this next year w/ tax return money. i own the same year blazer u do.
You do not need a 4X4 to have a lift. I've seen plenty of 2wd s-10's and blazers lifted. I have a 97 with a 2" B/L and a 2" suspension lift going in next week. Start with a body lift, it will not break the bank and if your reasonably mechanically inclined you can install it yourself in a weekend.
| All times are GMT -5. The time now is 09:00 AM. |
