2002 2wd
Old Oct 5, 2009 | 11:25 PM
tray29's Avatar
tray29 is on a distinguished road
Default 2002 2wd
hello,
i have a 2002 2wd ls and i was wantin to know your guys opinion/help on lifting it. any suggestions? Thanks!
Old Oct 5, 2009 | 11:45 PM
okvortec's Avatar
I'd recommend a body lift to start with.. see how you like it. A lot of the guys here run Performance Accessories Body Lifts, they're cheap and you can most likely install it yourself. If you decide you want bigger/better (and more expensive) things check out some suspension lifts.
Old Oct 6, 2009 | 01:19 AM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
Are you definitly set on lifting your 2wd? If I was looking for something to lift i would lean more towards a 4wd truck
Old Oct 7, 2009 | 07:16 PM
rocpede4x4's Avatar
rocpede4x4 is on a distinguished road
if u want to go higher of a lift, u can do a spindle converson from the same year S-10 pickup. and i'm doing this next year w/ tax return money. i own the same year blazer u do.
Old Oct 9, 2009 | 05:38 PM
cueball's Avatar
cueball is on a distinguished road
You do not need a 4X4 to have a lift. I've seen plenty of 2wd s-10's and blazers lifted. I have a 97 with a 2" B/L and a 2" suspension lift going in next week. Start with a body lift, it will not break the bank and if your reasonably mechanically inclined you can install it yourself in a weekend.
skygodtj
May 23, 2012 09:08 PM
mrgreazm0nkey
Jan 16, 2011 02:16 PM
venom01
May 24, 2010 09:41 AM
mr_dbc
Sep 16, 2009 01:17 PM
Jorgen
Nov 6, 2007 03:06 PM
