2003 with 31x10.50x15
im wanting to get wheel adapters 2" and im wondering if i need any kind of lift to do this....right now at full turn i rub on the INSIDE so i was wanting to widen then width track and give it a better stance?
You'll probably have to trim the front and back of the fender so it won't rub there as well.
i have 31x10.50 15 inch factory rim and no rubbing in the rear and the fron it rubs on the inside....
But spacers will push the tires outside the wheel well and they will rub, trust us
ok thats not a big deal...ordered 2 inches in the back and 1.5 inch up front to even the wheels out....
They will still rub up front with the spacer. You either need to lift it or break out the sawzall and do some trimming.
shouldnt have to cut to much off the front i wouldnt think?
Gonna be more than you think. I had a 98 4 door with 2 inch body lift and 3 inch susp with 2 inch spacers, lift and still had to cut an inch off to fit 31x10.5s
im going 1.5 in front and 2 in rear....
good luck
