2wd 2door 98 blazer v8 lift options
I am looking at building my 98 blazer. I plan to put a 350 sbc in it. I also want to lift it to clear some 31 or 32s.
The blazer is currently lowered, sadly they did it by blocks in the rear and Heating the front springs. :mad: So I have to buy new springs anyhow. So What springs should I get? Knowing I am going to be adding weight to the front with the small block, is there a stiff lift spring that can give me 2 inch of lift? If I can get 2 inch of lift then I will add 2 inch body lift. Maybe then I could clear 32s. Wife has me on strict budget so trying to do it as cheap as possible, knowing cheap and custom never go together. |
Did I ask the question wrong?
Using the 2" coils in front n 1" shakles in the rear, plus the 2" body lift will clear 31" tires. If u want to use 32" tires u will need to do some triming of the front fenders.
Originally Posted by rocpede4x4
(Post 486571)
31's should do me then. Thanks for the response. |
