-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   2wd/4wd spindle conversion? (https://blazerforum.com/forum/lifting-tech-44/2wd-4wd-spindle-conversion-39606/)
theclothedcreature Jan 21, 2010 08:47 PM
i have a 2000 blazer, wanted to lift it a couple inches for clearence. (body lift no help) already own 2" blocks and ubolts. was wondering about how to lift the front without throwing the near perfect alignment way outta wack. lift coils? or will spindles off a 4x4 s10/blazer do the trick?
comments please...
peace.
DriftinBlzr Jan 22, 2010 08:35 AM
Nope, the 4wd and 2wd spindles are not interchangable and even if they were the spindle heights are the same. So you can either get lift coils($) or lift spindles($$$).
Later, Doug
huntersblaze Jan 22, 2010 09:22 AM
Also the leaf springs run underneath the axle, so the blocks would only lower the truck in the rear.
rocpede4x4 Jan 22, 2010 01:37 PM
u can do a lift spindle conversion for a S10 pickup and brakes there a guy that did this to his 99 blazer and looks awsome and here is a link to his garage pics.
https://blazerforum.com/forum/album.php?albumid=895
