3" Shackles
Old Mar 10, 2008 | 04:47 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default 3" Shackles
Found a set of 3 in. shackles, i know putting the shackles on oyu gotta crank the t-bars. Was wondering if it would be to much to put 3" ones on.
Old Mar 10, 2008 | 04:49 PM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
Default RE: 3" Shackles
your going to be lucky if you can get 2" out of the torsion bars. so id say yea its too much unless you want your truck noticably higher in the back
Old Mar 10, 2008 | 05:33 PM
thanks
WolfPack's Avatar
If your front suspension is worn at all, you'll get an inch or so of lift at most. Then with 3' in the back, you're going to notice the forward slope. A little forward rake is classic SUV, but 2-3' of rake seems a bit much for an unmodified blazer.
Old Mar 10, 2008 | 09:55 PM
Im sure theres a note about this somewhere, but how much lift am i going to get off of 2" shackles?
Old Mar 10, 2008 | 10:03 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
if they are 2 inch lift shackles you will get approximately 2 inches....
Old Mar 10, 2008 | 10:04 PM
WolfPack's Avatar
Well if you wanna get technical, you're going to get a drop out of ' 2 inch ' shackles.
If you buy 2 inch LIFT shackles, theyre actually something like 4 inches longer than stock shackles. You take the increased length of the shackle, cut it in half (you're only lifting one side of the leaf spring) and that's your lift.
So...if you go to Synergy Offroad, or Fabtech, something like that, and find 2' lift shackles for a Chevy Blazer, you're going to get 2' of lift on the rear end.
Old Mar 11, 2008 | 03:39 AM
texastrails's Avatar
texastrails is an unknown quantity at this point
you'll actually lose about half an inch out of the given "height" of the shackle, so with a 2 inch lift shackle, which i think is like an actual 8 inch shackle, you'll really only be gettin about 1.5 inches of lift, so with your 3 inch lift shackles you'd be generating around 2.5, so even if you max cranked your tbars, you'd still have your forward rake, unless your leaf springs are worn to hell and saggin, then you might come out about even.
Old Mar 11, 2008 | 09:16 AM
WolfPack's Avatar
I have never heard anything of the sort. A 4 inch longer leaf spring shackle, lifted on half the spring, gives 2 extra inches of lift at a 90* shackle angle. If you install the shackle wrong (or at a 'custom' angle for whatever reason), you'll get less lift.
Old Mar 11, 2008 | 12:13 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
I know for a fact that Synergy Offroad, Fabtech, and Daystar shackles all are measured by the amount of lift they give... so if you get 2" SO shackles, your rear end will lift up 2".
