3 inch trailmaster body lift
this guy on criagslist wants $100 for the 3 inch trailmaster body lift of his 85 s10 do u think this same kit would work on my 88 jimmy s15
It should they're both 1st gen s-series and for that price I'd snatch it up and try it
Well, as far as 1st gen body lifts go. I payed under $100 for a new 3 inch PA body lift from Amazon.com. BUT if that is the older model trailmaster with the bumper relocation brackets, that would keep you from the need to fab up your own brackets. As long as it's in goodshape and you like it. It should work.
Only way to get that is if it has the bumper brackets. Not sure if the rear one is gonna work or not on a blazer but the front one might make it work plus the fact you won't have to mod as much.
Other than that you can get BLs cheaper and $100 sounds a bit high for a used one. |
Originally Posted by neo71665
(Post 295879)
Something to keep in mind. If that kit is used, see if it comes with the throttle linkage with the extension welded in. If not, I'd say that metal extension is missing and you'll have to fab something for that too. (Shouldn't be a big deal though). |
1/4 inch or 3/8th rod for the extension in a first gen. I forget exact size but it can easily be picked up at any hardware store for under $5 I bet.
