3inch body lift questions
Old 02-25-2009, 09:37 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: 3inch body lift questions
they dont make a 3" body lift for second gens only 2" however I have heard of a 1st gen 3" being used with some modification but if you go that route be prepared for some extra work, just a heads up before you start.
Old 02-26-2009, 11:55 AM
dober is an unknown quantity at this point
Yea i know ive been doing alot of research for this lift. A friend of mine has done this before and he is going to help me along the way. Im just going to look for 3" body lift blocks and buy the hardware my self. My friend knows to fab up some bumper brackets and all other mods im going to have to do. I was wondering if there is an upgrade for the ball joints. I had heard something about them but not sure. Any info anybody has would be greatly appreciated.
Old 02-26-2009, 12:19 PM
Outsydr's Avatar
body lift wont change your cv/ball joint angles if thats what your worried about but otherwise I recommend This kit its the best you can get for these trucks. As for the 3" kit check out This one. No bumper relocation brackets, however fuel filler extension etc is included and its much easier on the wallet than the others doubt you could buy blocks and hardware seperate for a better deal (but i have been wrong before) either way its worth a look. Good Luck!
Old 02-27-2009, 02:51 PM
thanks man i just checked it out. the body bolts that come with the kit will work with my blazer right?
Old 02-27-2009, 02:57 PM
now as far as bumper brackets go, could i use bumper brackets from a 1st gen and customize them to work with a 2nd gen?
Old 02-27-2009, 04:16 PM
Outsydr's Avatar
the kit I linked does not include bumper brackets I bought some steel and welded up my own so as for modifying premade 1st gen brackets I can't help you I have no idea.I would imagine the bolts would work see no reason why not.
Old 02-27-2009, 05:28 PM
there is one person that did a 3" body lift on a 2nd gen blazer. wrecked or somehtin likethat is is name
wlorton
Lifting Tech
14
10-31-2010 02:15 AM
96ProjectHighLife
Lifting Tech
05-19-2010 08:03 PM
1995ChevyBlazer
Lifting Tech
03-29-2009 11:05 PM
timetoblaze
09-28-2004 08:16 PM
Quick Reply: 3inch body lift questions
