91 4door s10 blazer SAS
Old Apr 10, 2012 | 03:34 PM
91tbi4.3's Avatar
91tbi4.3 is on a distinguished road
Default 91 4door s10 blazer SAS
I'm a little new here but i've been on s10forum.com for awhile and it seems there's a bunch of mini truckers but not a lot of off roaders on there so i'm giving this site a shot i have a 1991 chevrolet s10 4 door blazer 4x4. it "was" a 4.3 with an auto trans, i since then cut all the IFS off and put 3" lift waggy springs under the front and used skys off road designs cross member kit. the axles are from and 86' grand waggy with 35x12.50x15 BFG all terrains on american racing wheels. I'm also putting a 350 from an 89 silverado in and turns out it was bored .30 over here is my collection of pics hope you guys enjoy
before the sas: 2" lift and slight t-bar crank with lift shackles in the rear
engine all put back together with new gaskets/bearings ect.
frame stripped down and bedlinered
engine/tranny/t-case on the frame
exhaust
putting the body back on
floor pan rust
bodys not bolted down yet
body bolted down
interior in
little flex i could do with my jack
my blazer(left) my brothers(right)
currently fixing his head gasket which we just pulled the engine
hope to hear back from you guys!
Old Apr 10, 2012 | 03:40 PM
xgiovannix12's Avatar
nice man welcome to the blazer forum ...
you might have seen me around on the s10forum also ...
Old Apr 10, 2012 | 03:43 PM
91tbi4.3's Avatar
i have, only reason i know is because of your avatar haha
Old Apr 10, 2012 | 03:48 PM
=D yea man well this is the forum i spend most of my time on ..
Im on the s10forum once in a blue moon
and im on many more others
Old Apr 10, 2012 | 03:55 PM
91tbi4.3's Avatar
im only on this now and s10forum, i used to be on dezertdimes.com but thats all pre-runner stuff
Old Apr 10, 2012 | 06:08 PM
skotti's Avatar
skotti will become famous soon enough
welcome to the forums.
Old Apr 10, 2012 | 06:41 PM
abig84's Avatar
welcome. theres a mix of all kinda s10 people here. even a few SFA guys also
Old Apr 10, 2012 | 08:22 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
We have the same lift , I just finished putting the axles under it today . I still have to hook up the shocks and run the rear brake lines on the axle . You went with a better axle than me though , I decided to go with dana 30s out of a jeep wrangler with 4 inch super flex springs , I already wish I went with the 44s . I'm going to be installing the 35x 14.5 super swamper thornebirds this Thursday , Awesome build by the way . I have my hole build on this sight , I took pictures of everything .
Old Apr 10, 2012 | 11:32 PM
91tbi4.3's Avatar
I think I was looking through your build earlier and I liked it, I would of went with a d30 up front but I know I'm going to give it hell off road so I needed an axle that would Definatly take the beating. One thing I'm having issues with is I have people telling me the 4.3 computer will run the 350 as long as I change out the ECM on the distributer, then I have another half telling me just to switch the ECM out for a 350's.. I'm very confused about it
Old Apr 11, 2012 | 07:25 AM
skotti's Avatar
just run the v8 distributor so that wouldnt be an issue. I would guess theyre talking about swapping the v6 prom with the v8 prom inside the pcm. if you have the v8 pcm, just swap it in. if not you would probably need to send the 4.3 prom away to get reflashed to 5.7 prom. This is just stuff i recall reading when i was researching my swap. none of this applied to me, so i didnt read to much into it.
