Axel Flip-Kit
i want to do a Axel Flip to lift it but wondering about it like how hard is it does it take long is it really a kit or something i can do
RE: Axel Flip-Kit
Axle flip?
You mean a Spring Over Axle (SOA) conversion? That just puts the leaf spring on top of the rear axle instead of below it. This will give you approximately 5' of lift in the rear though...and unless you're going to get a solid axle for up front, you're going to have a rediculously severe foward rake (lack of lift in the front). |
RE: Axel Flip-Kit
yea i just saw it on a other forum said it can give up to 5 inches in front but i thought it would be cheap and can do it myself by just fliping it over.
has alot of info tho if anyones wnting to lift their 2wd s10 http://forums.s-series.org/viewtopic.php?t=40528 |
RE: Axel Flip-Kit
Ah...right..2wd...yes 2wds are much easier to lift the front end. The SOA is only rear axle though. No leaf springs up front to flip.
RE: Axel Flip-Kit
yea i know that, i just dont know is it pretty quik and easy to flip
RE: Axel Flip-Kit
I think all you have to do is take the weight off the rear suspension (just like you were going to do an add a leaf or shackles), unbolt the leaf spring, move over the axle, flip the U-bolts...you might need a new bracket piece to hold them, and then re-attach leaf springs. Only problem is that you then will need to extend brake lines, not to mention the driveline angles will be bad..
I also think I saw somewhere you may need access to a torch/cutter at some point...but that might be fore the entire lift. Again, I don't think this is something you just wanna go ahead and do...unless your going up 5' in the front as well. |
RE: Axel Flip-Kit
what is a good way to get 5inches up front? becouse id rather do a flip, ratherthen buying 3 inch shackles and add a leafs. the flip just seems cheaper
RE: Axel Flip-Kit
seeing as how your username is fla_blazer4x4..you don't have much options. You can do either a solid axle swap and do a traditional lift like a jeep or something. Or you can do a superlift/trailmaster lift kit that gives you leaf springs up front, and places them over the axle.
All those lifts you were looking at before are for 4x2s only. 4x4s have torsion bar front suspension, and thus cannot use spindles, lift coils, etc. |
RE: Axel Flip-Kit
no i have a 2wd 2005 blazer, i want to change my username but cant figure out how.
RE: Axel Flip-Kit
ORIGINAL: WolfPack seeing as how your username is fla_blazer4x4..you don't have much options. You can do either a solid axle swap and do a traditional lift like a jeep or something. Or you can do a superlift/trailmaster lift kit that gives you leaf springs up front, and places them over the axle. All those lifts you were looking at before are for 4x2s only. 4x4s have torsion bar front suspension, and thus cannot use spindles, lift coils, etc. |
| All times are GMT -5. The time now is 04:59 PM. |
