ball joints and pittman arm
Honestly for safety concerns take it to a shop, if its not something your used to doing it can be dangerous... I`m not being a wiseass either , I have the special press to remove the lowers out of the ctrl arm and i still dont wanna do them in my driveway.. The uppers ya need an air chisel to hack away the rivets that hold them in, and then ya need ball joint forks for the ball joints to break loose from the steering knuckle... If ya dont have that stuff it can get dangerous..
All you need is a drill, and ball joint seperator, the old school fork seperator will do just fine and is inexpensive. Takeoff the tire, either un-hook brake line or take off caliper, If you remove caliper be sure not to let it hang from the brake line as this will damage the line. Then unbolt balljoiints from spindle, use the seperator to break the ball joints from the spindle. Set the spindle aside. Now take the drill and drill the center of the rivets until the head is thin enough to knock them out. Install new ball joints, make sure they are greased properly, then install everything back the way it was. Pretty simple thing if you have any mechanical skills. I would recommend doing it yourself if you have the ability, I personally feel that mechanics rip people off so I do all I can to keep from going to one.
Spend the few dollars and get a good shop manual. It will pay for itself over and over.
I do have the 4x4 model and not only have I changed my balljoints, but I am finishing up putting on my 5" trailmaster lift on. With the truck lifted on stands the arms hang until they reach the bumpstops. There is not much tension on them from the torsion bars at all from this point. Just break the upper joint first if you are really worried about it and keep a jack under the lower arm to keep it from lowering the whole extra inch or so that the lower arm will try and drop. Or like everyone else said, if you have any doubt that you can perform this task then have a mechanic over charge you for such a simple task, at least if a mechanic does it and something goes wrong then they will take care of it.
Like my buddy above me stated, spend the money and get a book it will help you many times over.
well, oddly enough a similar job just got quoted by a place I have never used before. Screwed at a shop or no, as a result of a sweet accident, isurance will be footing the bill for 2 lower BJs (heh) at $60 each, 2 Upper BJs at $70 each, $170 for a hub assy. $50 for an alignment and $300 in labor later (ouch) it would be $780. lose the hub and you're looking at $610 or so BEFORE removing hub labor...
that seems steep as all hell to me, but hey, someone else's insurance bought it so... who am I to say no?
not all mechanics rip people off, its usually just a high labor rate, and mechanics are flat rate 90% of the time.if the job takes two hrs u pay for 2 hrs labor and the tech gets 2 hrs of pay. which could be from 12-25 an hr depending on experience. i wish that sterotype would go away, there are alot of good honest techs out there
