-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Body Lift for 1999 Blazer ZR2 questions (https://blazerforum.com/forum/lifting-tech-44/body-lift-1999-blazer-zr2-questions-63520/)
xachman17 09-27-2011 10:47 AM
i'm looking into putting a 2" PA Body lift on my 1999 Blazer ZR2. I was just wondering what modifications i would have to do? brake line extension, fuel tank neck extension, fan shroud adjustment, air intake adjustment?
Also, what all does the PA152 Chevy Blazer/ GMC Jimmy 2 " Body Lift(including ZR2) from Synergy.com come with? i wanna make sure it has everything i'm going to need before i order it. bumper brackets, etc.
thank you for any replies:icon_wink:
warthogdriver 09-27-2011 06:05 PM
if you look for the pdf file for the instructions on the site it is very helpful.
as far as modifications, nothing major.
fan shroud yes....comes with hardware for that
fuel tank ext, i skipped that one.
air intake...n/a i have a cold air in.
brakelines...no, just have to undo a couple of clips from frame and carefully flex them.
i then zip tied them down.
only real pain was the body mount bolts...soak them with pb blaster or (=) for a couple days before you start. and be careful not to snap them...that leads to lots of "fun"
other than that not to bad really...i did mine by myself, took me good share of a full day to do it.
just read the inst. a couple times and take your time, you should be fine.
best part of the lift....frees up lots of tight spaces, makes some work on the vehicle much easier.
xachman17 09-27-2011 07:55 PM
Thank you, that clears up alot! i'll for sure soak the bolts!
NVANZEE 09-27-2011 08:25 PM
yeah theres nothing major that needs to be done. I print out the BDS instructions. They are a lot better than the PA ones
xachman17 09-28-2011 09:07 AM
i might have to do that. i found the PA instructions and they seem pretty self explanatory but i'll try finding BDS' too.
Thanks for the Info
BlazHerZR2 10-19-2011 10:09 AM
hey man im doing the same lift this weekend 2 in body lift on my 2000 ZR2 did you have any trouble with anything besides the body mounts what didi you actually have to extended i have a cold air intake already. so just fan shroud, gas tank filler neck extension, brake line flex any one else find anything else that needed customization or finagling :)
xachman17 10-20-2011 09:53 AM
@ BlazHerZR2, i haven't done it yet so i know as much as you lol
@ Warthogdriver, since i dont have a cold air intake what would i have to do?
Old Skool Soldier 10-20-2011 12:02 PM
Run a search on youtube for my body lift install video. 2000 blazer LT body lift install or search my youtube name (same name as here) I did a step by step video.
-OSS
