-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Cheap lift (https://blazerforum.com/forum/lifting-tech-44/cheap-lift-79847/)
A2D customs 06-13-2013 10:38 PM
Cheap lift
I have a 98 blazer and I have a set of 31x10.50s bfgs wrapped around crugar -12 mm offset wheels I want put on it. will lifting the torsion bars and putting a 2 inch shackle lift look right and be able to turn I'm ok with a little rub
01blazer16 06-25-2013 01:02 PM
I'm not sure but a 2 inch body lift would fit 31s
KO-king 06-25-2013 03:02 PM
I have a 2.5" rouch country lift with 31" bfg and I had to do some decent trimming in order for me to turn without major rubbing. To be safe id go with a body lift and tweak the torsion bars up a little. not to much or it will cause front end wear!
El_Beautor 06-25-2013 03:20 PM
Most people need more than just a t-bar lift to clear 31's safely, especially if they're on low backspace rims. Like KO-King said, a t-bar lift, shackles in the rear, and a body lift should clear 31's fine. I did 31's like that for quite a while before I went up to 32's and had to start chopping my fenders.
Stevenadamski 08-03-2013 05:51 PM
I run 30s on stock rims with a tbar crank, stock otherwise and i dont rub until full lock. Ive got room too so im sure i could run 31s with no problems as is
T...K21 08-04-2013 07:01 PM
Just out of curiosity. All the 2nd Gen S Blazer and Jimmy were push button 4wd right? So when adding a body lift...you aren't fighting the t-case shifter on the floor, fan shroud, and brake lines.
I base my question on owning a couple 1st gen GMC S-pickups in the past.
newguy 08-04-2013 07:21 PM
You still have to mess with the shroud and brake lines a bit. t case stuff no
HotRodHearseGuy 08-07-2013 01:12 AM
I've also got a '98 Blazer and currently running 31's on my stock wheels and only time it rubs and its only SOMETIMES, it at full lock. I'm running at stock height with no adjust on the t-bar.
