custom lift
Hey guys.
Quick question for the engineers. I'd like to lift the rear axle of my 1980 k5, only the rear and only 1". I do like the way it rides, so i actually dont wanna change the leafs or shocks and i don't wanna lift the front. I like the esthetic look of a little edge setup. How can i accomlish that? |
You could get longer shackles. Usually 2" longer shackles will give you a little over an inch of lift without changing your factory ride
1" Zero Rate 'Add-a-leaf' spacers are what you are looking for. I picked up a used set a few years ago for like $20.
Shackles won't work on the rear of a K5 as the rear shackles are inverted. A shackle flip typically adds ~4" of height to the rear using a stock shackle. |
^ ah I wasn't aware of that. Thanks for clearing up my misinformation
Thanks :-) I'll take a look
| All times are GMT -5. The time now is 04:28 PM. |
