-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Easy lift (https://blazerforum.com/forum/lifting-tech-44/easy-lift-78535/)
BCKDOOR SL4MMER 04-10-2013 11:22 PM
Easy lift
I'm just wondering if there is anyway I can achieve some bit of lift with just doing shackles or new leafs
gitch93 04-10-2013 11:44 PM
this topics been coverd a million times if u do some searcing in the feild. easiest way to get lift is a torsion bar crank and add some shackles. its the poor man lift. if u wanna spend some money u can add a leaf and some indexing keys. or 2 options buy a body lift that will give u 2 inch lift and a manufacturer suspension lift kit. everyone seems to use the roughcountry 2.5 inch lift very basic but functional as i use it my self.
00chevblazer 04-11-2013 08:43 AM
Its been covered many many times on this forum. A search might help ya narrow down what you're looking for. But shackles and a t bar crank is realatively inexpensive and doesn't require you to buy addition parts. Well besides an alignment and rear shocks. Pretty straight forward install that will give you some lift and some noticeable height difference between a stock blazer. If your looking for bigger tires with this lift also, 31's is about the biggest you can get. I know others have fit bigger but that requires cuttin and beating. Which I didn't wanna do with mine.
BCKDOOR SL4MMER 04-11-2013 01:48 PM
well my blazer sags to one side so i was gunna do leafs anyway. but do you mean lifted shackles?
