-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Getting High (https://blazerforum.com/forum/lifting-tech-44/getting-high-101517/)
Heftynoma 04-17-2020 11:23 AM
Soo once upon a time I bought a blazer and it was awful. Beat to poop had like 10 lbs of oil pressure max. So I Sold it to my dumb sister for over double what I paid.
A couple years later I got a super clean Sonoma It was my dd and wheeling toy. I ended up destroying cv’s, bj’s, hubs, and crashed into a pole. So I went out and got a pair of 79 f250 axles 44/60 combo, with flat tops. Got junk yard Dakota springs, ranger spring hangers and I am still acquiring parts. So far I’ve got my front crossmember mounted and the og one cut out. Front spring pack together and cut out the hump on the driver side of the frame to make it look like the other side. Now for pictures.
https://cimg4.ibsrv.net/gimg/blazerf...9298b6b71.jpeg
https://cimg5.ibsrv.net/gimg/blazerf...194ecc266.jpeg
https://cimg5.ibsrv.net/gimg/blazerf...a23dcc3a3.jpeg
https://cimg6.ibsrv.net/gimg/blazerf...e1f315b76.jpeg
https://cimg7.ibsrv.net/gimg/blazerf...af704f8f3.jpeg
https://cimg8.ibsrv.net/gimg/blazerf...4f839d5f9.jpeg
https://cimg0.ibsrv.net/gimg/blazerf...af8b018d7.jpeg
https://cimg3.ibsrv.net/gimg/blazerf...7bc3579b6.jpeg
https://cimg4.ibsrv.net/gimg/blazerf...5ac0f9e8a.jpeg
https://cimg5.ibsrv.net/gimg/blazerf...edb089036.jpeg
https://cimg8.ibsrv.net/gimg/blazerf...b199dd2bb.jpegDid some work tonight got the hangers tacked in place. And I started to get the old perches off my 60
https://cimg7.ibsrv.net/gimg/blazerf...d90faf2ca.jpeg
https://cimg9.ibsrv.net/gimg/blazerf...33e15bcfb.jpeg
https://cimg1.ibsrv.net/gimg/blazerf...bfd65e4b1.jpeg
https://cimg2.ibsrv.net/gimg/blazerf...e4309ba03.jpeg
so I got some stuff done as you’ll see. Got the truck on the wheels. Shackle angle is iffy. Might wanna bring them a little forwards.
https://cimg0.ibsrv.net/gimg/blazerf...42f222db8.jpeg
https://cimg1.ibsrv.net/gimg/blazerf...5b0121db2.jpeg
https://cimg4.ibsrv.net/gimg/blazerf...f266563f1.jpeg
Ground to bottom of frame 18.5 with 27” tires. Not bad.
https://cimg7.ibsrv.net/gimg/blazerf...df52498ac.jpeg
Update. So I cut my shackle mounts off and moved them like 2 or so inches forwards. In the process I have to cut my exhaust. No biggie
Ended up with 30 degree shackle angle
https://cimg1.ibsrv.net/gimg/blazerf...9a2f5f027.jpeg
Neither of these shackle pics have weight on the truck.
https://cimg5.ibsrv.net/gimg/blazerf...de69389e1.jpeg
Cut the chin spoiler off my bumper and threw it in to see what it’s gonna look like.
https://cimg0.ibsrv.net/gimg/blazerf...61df07c31.jpeg
These are stock 8 lug Steelies and they stick out just a little bit lol.
https://cimg3.ibsrv.net/gimg/blazerf...7081e4994.jpeg
Got a bunch of parts in. Still waiting on a few things tho.
https://cimg8.ibsrv.net/gimg/blazerf...5fd832cc2.jpeg
Last piece of the puzzle.
UPDATE. Welded on my rear perches and set my pinion angle.
https://cimg4.ibsrv.net/gimg/blazerf...ee69034a8.jpeg
https://cimg2.ibsrv.net/gimg/blazerf...af011adc6.jpeg
U bolt eliminators almost done.
https://cimg7.ibsrv.net/gimg/blazerf...f65a89e22.jpeg
Full droop. Replacing all brake parts
https://cimg3.ibsrv.net/gimg/blazerf...0475ff272.jpeg
https://cimg4.ibsrv.net/gimg/blazerf...2c364a7af.jpeg
Took abs bull poop off and got a regular disk/drum prop valve
Nfbfj Nxhe 06-08-2020 09:46 PM
Does this thing have ladder bars?
Does this thing have ladder bars? Asking for a friend
Heftynoma 06-10-2020 09:58 PM
https://cimg9.ibsrv.net/gimg/blazerf...49e5136ff.jpeg
Made a bracket for my prop valve
https://cimg0.ibsrv.net/gimg/blazerf...bec8f6c80.jpeg
Got about 20’ of brake line, probably gonna need a little more
blazen_red_4x4 06-10-2020 10:30 PM
I like the progress! And the backstory lol
Not going to lie though, I'm a little concerned about the use of what looks like the 90 amp 120v Harbor Freight flux core welder used to stitch together a SAS. I have the same welder and I wouldn't trust it to get enough penetration to weld a new tongue to my trailer lol
christine_208 06-10-2020 11:23 PM
Cool build. I'll be looking forward to more updates!
Heftynoma 06-11-2020 06:29 PM
https://cimg6.ibsrv.net/gimg/blazerf...b95202b27.jpeg
Got all my drum parts and ball joints. Also got the filter fitting to put it on the block. The welder is a 220 flux core and it can burn holes in 1/2 steel if I wanted to. Not a concern at all.
blazen_red_4x4 06-11-2020 06:42 PM
Lol okay that's good then :)
Heftynoma 06-19-2020 03:53 PM
https://cimg5.ibsrv.net/gimg/blazerf...ca0fd7e4e.jpeg
Brake line holder, just need to use my dads hydro flare tool and lines are done.
https://cimg3.ibsrv.net/gimg/blazerf...a42de2479.jpeg
Packed bearings, new outer seals
https://cimg6.ibsrv.net/gimg/blazerf...d981831c5.jpeg
Breather and brake hose bracket
https://cimg3.ibsrv.net/gimg/blazerf...e1f87e455.jpeg
Cutting off and folding my quarters
https://cimg9.ibsrv.net/gimg/blazerf...8b8120aa4.jpeg
Started on a rear bumper
https://cimg1.ibsrv.net/gimg/blazerf...5460d1c0b.jpeg
Made a winch mount
https://cimg2.ibsrv.net/gimg/blazerf...a63f96bd2.jpeg
the ford steering arm was giving me problems so I turned the studs in to bolts.
https://cimg4.ibsrv.net/gimg/blazerf...a655c064f.jpeg
https://cimg3.ibsrv.net/gimg/blazerf...b4fce6523.jpeg
Got the stock bumper to fit over the winch. Look closely it’s in there.
https://cimg3.ibsrv.net/gimg/blazerf...ab00d2f67.jpeg
3” intake and still using the stock air box and filter.
https://cimg2.ibsrv.net/gimg/blazerf...701980679.jpeg
Finished my rear bumper.
https://cimg7.ibsrv.net/gimg/blazerf...37515f26d.jpeg
Update 8-10-20 Took the bed off
https://cimg9.ibsrv.net/gimg/blazerf...43dafebd2.jpeg
Took this cross member out, stock shock mounts and all the spare tire bs. I will be mounting a sway bar to the crossmember before I reinstall it.
https://cimg0.ibsrv.net/gimg/blazerf...57a53952b.jpeg
Fixed rotted cab/bed mount.
https://cimg1.ibsrv.net/gimg/blazerf...76ea05066.jpeg
Spare tire crossmember turned in to sway bar mount
https://cimg3.ibsrv.net/gimg/blazerf...9a695fc6b.jpeg
Full droop links for sway bar
https://cimg6.ibsrv.net/gimg/blazerf...619ae0cf6.jpeg
Painted front cover silver
https://cimg1.ibsrv.net/gimg/blazerf...e1e4cac55.jpeg
Update 8/21/20 Hole for body mount
https://cimg3.ibsrv.net/gimg/blazerf...4e3cda700.jpeg
Welding can mount back on
https://cimg5.ibsrv.net/gimg/blazerf...b8153af86.jpeg
Fully welded sway bar mounting spots
DonL 08-21-2020 08:22 AM
Coming along. Looks good.
Heftynoma 08-22-2020 08:42 PM
https://cimg7.ibsrv.net/gimg/blazerf...abfb020a4.jpeg
Front brake hose bracket.
Heftynoma 08-22-2020 08:44 PM
thank you. What does everyone else think?
Heftynoma 09-22-2020 06:16 PM
https://cimg4.ibsrv.net/gimg/blazerf...58cd734f5.jpeg
Not much progress just Made a new tranny crossmember
https://cimg6.ibsrv.net/gimg/blazerf...5c3398bbf.jpeg
Machined, drilled and tapped my passenger knuckle all in my basement.
https://cimg8.ibsrv.net/gimg/blazerf...c0be718f7.jpeg
https://cimg9.ibsrv.net/gimg/blazerf...e880eb7b5.jpeg
https://cimg0.ibsrv.net/gimg/blazerf...5316eda9a.jpeg
Back on all fours
https://cimg2.ibsrv.net/gimg/blazerf...c4bae385b.jpeg
Making sure there’s no binding issues
https://cimg6.ibsrv.net/gimg/blazerf...0d60fd32a.jpeg
https://cimg7.ibsrv.net/gimg/blazerf...867f9d1ab.jpeg
https://cimg6.ibsrv.net/gimg/blazerf...4cce0aa4d.jpeg
Made my drag link
https://cimg8.ibsrv.net/gimg/blazerf...d10b653ff.jpeg
Reamed pitman arm
https://cimg4.ibsrv.net/gimg/blazerf...980cb7021.jpeg
Slapper bars :)
https://cimg0.ibsrv.net/gimg/blazerf...47a7731e2.jpeg
Made a fair lead mount. Getting down to last 20 or so things left to do.
https://cimg6.ibsrv.net/gimg/blazerf...607351d76.jpeg
Tubular Winch supports
https://cimg7.ibsrv.net/gimg/blazerf...b6062a3c3.jpeg
DonL 11-28-2020 06:03 AM
Looking good, coming along nicely
Heftynoma 11-29-2020 07:32 PM
thanks man.Getting super excited everyday I get something done on it.
Heftynoma 12-04-2020 04:42 PM
Started making some sliders
https://cimg2.ibsrv.net/gimg/blazerf...a7ba5ebcd.jpeg
https://cimg5.ibsrv.net/gimg/blazerf...6937319fa.jpeg
Passenger slider
https://cimg4.ibsrv.net/gimg/blazerf...5c087a371.jpeg
Chicago locker
https://cimg5.ibsrv.net/gimg/blazerf...6434a893c4.jpg
Automatic locker for the front
https://cimg1.ibsrv.net/gimg/blazerf...185d87a46.jpeg
Pulled the front axle and everything off it. Just waiting on my axle seals.
https://cimg3.ibsrv.net/gimg/blazerf...e20a86c14.jpeg
Made an oil catch can.
https://cimg2.ibsrv.net/gimg/blazerf...7e885ec89.jpeg
1/25/21- pulled my carrier out and was ready to install my locker but my thrust washers had about 10 thousandth wore on each. So I ordered new ones, along with 13” travel shocks.
https://cimg2.ibsrv.net/gimg/blazerf...52e408d85.jpeg
Axle seals and locker installed.
https://cimg2.ibsrv.net/gimg/blazerf...b33a27072.jpeg
axle is back in. Started on shock mounts. Need to make steering spacer.
DonL 02-27-2021 07:54 AM
Getting somewhere! Looks good. Those are long arse shocks! Lol
Hess13x 03-01-2021 08:15 AM
Dang how did I miss this build? Looking good!
Heftynoma 03-03-2021 03:23 PM
https://cimg7.ibsrv.net/gimg/blazerf...facf72e70.jpeg
Shock tower. Took a different approach then most people. How’s it look?
DonL 03-03-2021 03:37 PM
I think you might need the "loop" to keep it centered. But I like it
Tom A 03-03-2021 06:20 PM
Looks to me like it will eventually fatigue and break off.
Heftynoma 03-04-2021 07:56 AM
have you guys even ever welded 😂.
Tom A 03-04-2021 08:05 AM
I've been welding for 40 years and I'm a lot better at it than you are. I don't get what's so funny.
DonL 03-04-2021 08:06 AM
Lol yes, not a lot, but enough. I'm not saying nothing bad about the welds.... just think a single support will flex after time with enough force on it, no mater the welds...
