-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   height stock questions?? (https://blazerforum.com/forum/lifting-tech-44/height-stock-questions-45375/)
XtreemeBlazer Jun 4, 2010 09:16 PM
Ok im getting ready to do the Tbar crank and shackles. i measured the height from the top of the wheel well to the top of the rim. my front was 10 1/2 inches and the back was 12 inches. is it spouse to be that much off or does it have to be the equal in the front and back?
old skool luvr Jun 5, 2010 12:11 AM
whenever i've lowered or raised a vehicle, i've gone buy the rockers. (measure the wheel wells on an old skool full size Chevy.......they're different in relation to the rockers)
XtreemeBlazer Jun 5, 2010 07:47 PM
yeah im just trying to find out if its still at stock height before i to the tbar crank. my truck seem a little higher then other blazers so not sure if someone did some mods to it. the shackles seem to be stock but i dont really know by just looking at them.
Zachlee08 May 18, 2011 12:16 AM
Whats your height from ground to middle of wheel well? front and back please?
96chevy4dr Apr 25, 2012 10:02 AM
Any measurements from the ground to anywhere on the car is not a good way to measure because of tire height. My 235/75 r15 would measure different compared to someone with 30"s and so on. also the treadwear can contribute to differences in measurements. The most accurate way to measure the height is from the exact center of the rim to the fender well. Mines about 19" if i remember correctly. Also id like to know others measurements cause i want to know if my torsion bars are sagging. Also if you could list if u have cranked torsion bars or added shackles so we can compare!
Jase1979 Apr 25, 2012 04:06 PM
Bought my 98 4dr ls model used and it was set at 18.25" front and rear measured from center of wheel to fender lip with 235/75/15 Goodyear wrangler all season tires
