How high should I go?
Old May 14, 2009 | 07:02 AM
tdbaker10's Avatar
tdbaker10 is on a distinguished road
Default How high should I go?
My question is i was thinking about a 3 inch lift and I wasnt sure if I would have to get a stiffened suspension or not. What I wanted was just to put the blocks in that just give it a little more height, Im not looking to go off roading, but I do want to make it look beefier. If not a 3 then maybe a 2? Its a 2001 blazer 4 door, 4x4 and a V6
Old May 14, 2009 | 07:30 AM
blazen99's Avatar
blazen99 is on a distinguished road
pretty sure u can only get a 2 inch lift for that. plus if u do a tbar crank and shackles thats another 1-1.5 inch lift u will get so thats ur 3 ur looking for then u should be able to get 31s under there no prob.2 inch lift about 240 bucks shackles 30-60 cheap upgrade.
Old May 14, 2009 | 11:41 AM
nj4x4blaze's Avatar
I would just suggest doing a 2" body lift with some 31" Mudterrains.
Old May 14, 2009 | 02:51 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if your looking for lift DO NOT buy blocks, since the leafs on our trucks are below the axle blocks will only lower ur truck.
mcdevin1973
Oct 5, 2014 02:52 PM
jsschlimm
Lifting Tech
Jan 3, 2014 05:12 AM
trobbins
Jan 9, 2013 10:17 AM
tpis15
Sep 20, 2007 07:08 PM
jeff505
Tires and Wheels
Sep 12, 2005 07:03 PM
