How To: Rough Country 2.5" Lift Install
Old Oct 28, 2012 | 10:44 PM
  #21
Rottidog's Avatar
Lol yeah he said the other day you two gave the tbars a bit of a twist. He noticed that my cv's are a little straighter. I may have to twist the bars a bit for clearence on the 32 x 11.5's. Damn things are fat on 10" wide rims so I may give them 1/2" twist, nothing crazy. I like them being straighter than stock.
Old Oct 29, 2012 | 03:02 PM
  #22
Maurer6156's Avatar
Maurer6156 will become famous soon enough
Originally Posted by Rottidog
Maurer, Have you re-tightened the componants you've r/r or just replaced during the install?
Ive had it aligned and when they did that i asked them to double check the front, It makes a clunking/knocking noise-ish every little bump i hit.
Sorry Im not trying to threadjack!
Old Oct 29, 2012 | 06:48 PM
  #23
Rottidog's Avatar
It may not be related, just a coinkey-dink... have you folded a small rag & stuffed it under the hood by the hinge on either side?
Opened a front door & lifted it to look for play?
The rag trick will tell you if you have worn conical washer on the hood hinge & the door lift will point out worn door bushings. Both make odd sounds that don't seem like they could come from their respective areas.
Old Oct 29, 2012 | 08:00 PM
  #24
Maurer6156's Avatar
No it isnt the hood and i just did both door hinges in may. Had to weld the driver side bar for the latch. The sound is coming from the wheel wells
Old Nov 10, 2012 | 09:31 AM
  #25
blaz's Avatar
blaz is on a distinguished road
I was able to test out the flex a bit. The front is stiffer than before for sure, but it still stuffs the tire.
Old Nov 17, 2012 | 02:30 PM
  #26
kiwichev's Avatar
kiwichev is on a distinguished road
looks good! great write up. alot more work involved than what i first thought.... so back to the drawing board about a lift kit.
Old Nov 18, 2012 | 09:57 PM
  #27
blaz's Avatar
It was a lot of work, but well worth the trouble. I did a 2" body lift and that took 10 hours also. If you take your time and don't plan on getting it done in a day (take a long week end with some friends). Then again you could pay some one to install it. The 5" or 6" lifts will be more work I would think.
Old Nov 19, 2012 | 05:49 AM
  #28
mmmrodge's Avatar
mmmrodge is on a distinguished road
I did this lift and a body lift as well. I "took my time" and put in a few hours here and there...took me 3 weeks haha. I was quoted $500 for both jobs, great deal but you wont have the satisfaction of saying, yeah I lifted MY truck. Well worth the time and effort when it is done
Old Dec 10, 2012 | 04:01 PM
  #29
dustinhxc's Avatar
dustinhxc is on a distinguished road
great write up man!
Old Dec 29, 2012 | 03:41 PM
  #30
wannabelifted's Avatar
wannabelifted is on a distinguished road
im lookin at the 2.5" lift for my 93blazer. u think all the cuttin and eveerything u guys went thru will apply to that too? if so i'm in over my head here
