i need advice
okay so ive had s-10s and blazers forever but i always go down
but im getting a 4 door 4wd and i wanna lift it i have a set of 31x10.50 will they fit with a t bar adjustment until i get the suspension lift? also where does everyone get there front brushguards from i like the looks of them and would like one thanks for the help guys |
RE: i need advice
Short answer, no.
You will have to beat the snot out of the fire wall and cut the fenders to get them in. And then you will need to have the right back spacing on the rims as well. I know that this question has been answered before with much greater detail than I have provided... |
RE: i need advice
thats all i needed to know like i said i always lower them
thanks |
RE: i need advice
damn going up is alot more expensive then going down i could have dropped my blazer 6 inches for like 5-600 bucks but a 5-6 inch lift is like 1600!!
RE: i need advice
2" bl will fit 31's as long as your using a stock rim with 6" of back space. Not sure what year yours is, but you should be able to purchase a BL for under $200.
RE: i need advice
Yes, with a TB crank and a 2" BL, they will fit. But the BL was not in the original question.
RE: i need advice
yea i dont like body lifts dont like the gap between the frame and body when i do a lift it will be all suspension
RE: i need advice
They sell gap guards that cover that gaps between the body and the frame.
