i need advice from anybody willing to give it
well from what i have found the best bet for me is to go with a rough country 2" suspension lift and then a 2" body lift. i have searched for something bigger and haven't found anything that looks promising, the best part of this setup is i'm spending less than $500 on it all
have you even looked around for one? they all seem to be pretty much like that, at least around here. yes i know the roof was an option (kinda glad mine came with it), but what you're wanting to do to your truck, really makes no sense-can you say poser?
sorry if that sounds harsh, but why waste your time lifting a 2WD truck? dump it like they should be. it's waaaaaaay more expensive to raise a 2WD-kinda like it is to lower a 4WD truck. if your Dad is going to be that pissed about you selling it (he did give it to you right?) then maybe you should just let it stand as it is.
Here's a question for you (just curious). Why did you choose to go with a 2" suspension lift over say a 2" shackle and tbar lift? The cost difference is huge.
what trim package does your blazer have now? leather and power everything? you could get a base modle 98 LS 4x4, 2 dr or 4, and just swap out the leather from your old ride into it. there are a lot of options available to you.
if you can get a 2" sl AND 2" bl for $500, why not get a 2" bl and a 2" t-bar-and-shackle "sl" for $230 after s&h ?
The problem with the 2wd Blazer is I beleive it has coil springs in the front and not torsion bars. What you should look into are either larger front springs ore some kind of spring spacers in the front, shakels in the rear and the body lift. I know there are companies out there that make spacer kits for the Envoy's and Trailblazer's so I would start there. I think I have a link on my computer at work for 1 so I will post it up when I get it.
did you 2 (meaning Alex & Curtis) seriously not know that only 4x4's have the t-bars? at least Alex was telling the truth earlier, when he said there was a reason he didn't answer tech questions (much).
the kit i found comes with front coil springs, nitro shocks, rear lift shackles, and a steering stabilizer all for $407 thats price, tax and s&h
LMAO! i did know 2wd have no torsion bars BUT i totally forgot that was why we were dealing with the trouble in finding the kit!!!
