-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   lift help/advice (https://blazerforum.com/forum/lifting-tech-44/lift-help-advice-36830/)
xc2strokestomper 11-09-2009 08:40 PM
lift help/advice
im looking for a little bit of a lift and soem bigger tires. a budget build would be the best. ive been looking around and it seems like a body lift and shackles with the t bar would be the easiest? and cheapest? i dont want anymore than 4 inches. i just want a little more aggressive look to it. maybe a 2 inch body lift? with 31's? anyone have any suggestions on what to do for a 3 or 4 inch lift total?
also i would like to try some wheel spacers to help with the handling once its lifted. what size spacers do people usually use? 2 inch?
thanks guys
NVANZEE 11-09-2009 08:53 PM
do exactly what you said and you will fit 31s. If you get spacers dont get cheap ones they will break. Also with spacers you wont be able to use 31s unless you want to do some cutting. The farthew the wheels stick out the smaller the tire you can fit.
xc2strokestomper 11-09-2009 08:56 PM
maybe get a wider wheel/tire rather than wheel spacers then?
coivabs09 12-06-2009 05:58 AM
lift help/advice
I never noticed this thread. Did you get it finished? Whats the brand of your lift? Did you try contacting the company for help?
