lift leaf springs?
my stock leaf springs were saging when i bought my truck so iv done a 2in lift shackle and a rough country aal and the back is still sitting lower that the front with the 2.5 in rough country lift its a 2002 zr2 does anybody know if someone makes a 1" or 2" higher leaf spring preferably something stiffer so they wont sag again
is there a difference between a s10 zr2 leaf pack and blazer zr2 pack also iv heard older 1/2 ton chevy rear springs fit right in anyone tried this and if so would they sit higher thanks |
what i did was go and get a pack of springs from a blazer with the "z85" option then made a bastard pack by adding my old longest leaf to the yard packs...added an inch or so and a little stiffer ride.
as far as two door options i am not sure. |
im having the same problem, i added ALL and lift shackles last summer, after install i was about half an inch higher and now im about the same im sure its only going to get worse.
By the time your done adding this and adding that you could just by new springs
Originally Posted by newguy
(Post 566208)
Originally Posted by BlazerGarden
(Post 566210)
yes looking back i would have done this
