Originally Posted by Sisk
(Post 310072)
It's got a 2" body lift from factory. You definitely have a ZR2. They come stock with 31x10.5
Exactly what I was looking up. |
(Post 310072)
Are you sure about that? I was pretty sure it was a body lift...
As per wiki (not that wiki is always right...but): The following factory-installed features are what made the ZR2 standout from other 4x4 trucks offered in the S-Series class. Ladder Type Frame with Modified Mounting Points 100mm wider track (3.9 inches wider than regular S-10) Increased Ground Clearance (Approx 3" over Regular S-Series 4x4) Enhanced front (7.25" ring gear) and rear (8.5" ring gear) axles w/ 3.73:1 rear-axle ratio Larger wheel and axle bearings 31 x 10.50" BFG A/T Tires (Pickup), 31 x 10.50" BFG Longtrails (Blazer) Fender Flares Spectra Gray on the Chevrolet Models, despite body color. Body color on all GMC Models. 46mm gas pressurized Bilstein Monotube shocks Rear Track Bar (Pickup), Front Anti-Sway Bar (Blazer) Skid Plates [1] Front/Rear Disc brakes (1998-2005) , Disc/Drum brakes (1994-1997) Full Size Spare Tire http://en.wikipedia.org/wiki/RPO_ZR2 To me that says body lift...but I could be wrong. I've been wrong in the past lol. |
would this pose any problem if i wanted to but another 2" body lift on it?
Yes...If it is a stock 2" body lift (which I'm pretty sure it is) you wouldn't want another BL on there. That would be 4" of Body lift. Although it's been done before it's pushing what is safe and what isn't. I wouldn't recommend anything above 2" of body lift, even though they do make 3" BL kits I personally wouldn't feel safe putting one of those on.
You can get an extra 2" by putting new (bigger) shackles on for ~$60 and then cranking your tbars in the front for equal lift. Plenty of info around the forum for this method of lifting including lots of pics and tutorials, just do some reading. |
Check your RPO codes in your glove box. It will say ZR2. Def looks to be a ZR2. Congrats!
(Post 310136)
