-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Lifting a 2005 ZR2 (https://blazerforum.com/forum/lifting-tech-44/lifting-2005-zr2-11448/)
vtblazer 06-24-2007 01:52 PM
Lifting a 2005 ZR2
I have been thinking about lifting my 2005 blazer ZR2. Not looking to spend a ton of money. Was thinking about doing a 2 inch body lift and leaving the stock wheels. i haven't been able to find a kit for the 2005 -- all of them only cover up to the 2003 or something. was wondering what anyone knew about lifting one of the newer models. also wondering what size tires i could expect to fit with that and if it would be a reasonable project to try to take on myself. pics of someone who's done it would be awesome.
jimmyboy 06-25-2007 07:14 AM
RE: Lifting a 2005 ZR2
i would check out zr2usa.com they might be able to help you out.
jimmyboy
Jigg 06-25-2007 10:41 AM
You want performance accessories kit # 152. It'll fit your '05, even though it doesn't say so.
Here's my BlaZeR2 with a 2" BL, 1" t-bar crank, 2.25" shackles, 1.5" AALs, 1" Air Shocks, trimmed wheel wells, stock sized rims, and 33x12.50 BFG MT KM's:
http://img.photobucket.com/albums/v9...2/pics-006.jpg
http://img.photobucket.com/albums/v9...2/pics-007.jpg
PJT2007 10-19-2008 02:19 AM
Wicked, i am getting ready to buy a ZR2 with those same rims on it, what size are they?
AJBert 10-19-2008 11:09 PM
Damn, Justin, you even whore your truck over here!
The stock size of those wheels are the same as any other 4wd Blazer, 15X7 with 6" backspace.
BDS also makes a 2" BL and most that buy the PA BL use the BDS instructions. You can do the job yourself if you can turn a wrench and follow instructions with a basic set of tools, but air tools makes things much easier and quicker. You will also need a jack, preferable floor jack, that has a pretty high lift. Otherwise, you will have a heck of a time lifting the body.
Plan on a full day to do the job with a friend or two helping out. Some have done it by themselves so you can do it by yourself. Just take your time, follow the instructions and don't get in a hurry.
You "should" be able to run 33X10.5 with very minor trimming or 33X12.5 with a bit more trimming, depending on what rims you are going to run.
