-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   lifting 2wd (https://blazerforum.com/forum/lifting-tech-44/lifting-2wd-80934/)
01blazer16 Aug 6, 2013 02:26 PM
lifting 2wd
I'm gonna lift my 2001 chevy blazer 2wd. And wanted to know will it look good with 2 in body plus 2 in rough country with 31s? Reason I wanna do both is I don't want my 31s to rub when I hit bumps in road or on my dirt road? Also, should I go with 3.73 gears sence I want my truck to feel like stock with 31s? Thanks
cleburne red Aug 6, 2013 06:12 PM
What gears do you have now? 31"s are just a couple inches taller than factory 235/75's, so I wouldn't think a re-gear would be needed. If you really want to see where you would be, there are gear ratio calculators online, and you can compare your current setup to a new one.
01blazer16 Aug 6, 2013 06:38 PM
I have 3.42 now I just don't want it to be that sluggish sence I'm a vol firefighter
Twip Aug 6, 2013 07:22 PM
if you dont change the gears, you will be at about 3.20:1 on the rear end.
if you want to keep the same performance, you would basically need a 3.65:1 rear end.
so yes, you would want to change to the 3.73's if you want it to drive the same. if you dont change them, you would effectively have a 3.20 as your rear end gear. you might be sluggish off the line but then it would start to "freight train" when you get high in the RPM range. i dont know if you will be able to find a 3.73 rear end in 2wd. you might have to buy some parts. which wont be cheap. unless you know how to set up a rear end yourself.
just my .02
AndrewO1991 Aug 9, 2013 08:37 AM
if you like seeing all that frame exposed then ya a body lift looks good, personally i could never bring myself to do it
chris015 Aug 9, 2013 08:42 AM
just my .02
oldsmobile bravadas has 3:73 with g80 on some of the 2wds. and direct swap out too with ours. (make sure its 2wd for 2wd,and 4wd for 4wd)
AndrewO1991 Aug 13, 2013 10:00 AM
bravada's are all awd which is similar to a 4x4 except the front axle has no vacuum actuator
