Hahaha! You should be fine with just lifting the front to start. Like newguy said just be away that your vehicle dynamics may be off a bit and take it easy.
I dont know Rex....the caster on the front will be way off due to
The front lift...driveability will be "special" aside from looking Completly stupid driving down the road....I would suggest New rear shackles and bolts...also new rear bushing and it will be a complete swap with no messing around with the stupid Bushings...just cut out the old shackles and install new shackles and Bushings.....3hours tops.....front springs just a couple hours Bam.....on the road again....then go and buy a 4WD |
Its only 2 inches, 5 may be a problem
| All times are GMT -5. The time now is 08:09 AM. |
