-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Looking for cheap lift (https://blazerforum.com/forum/lifting-tech-44/looking-cheap-lift-41417/)
jimmy979 02-26-2010 07:43 PM
Looking for a 5 or 6 inch lift for my 97 Blazer but looking to find the best posible price. its 4wd and 4 door.
ABN31B 02-26-2010 08:04 PM
5-6" total lift?
suspension lift?
safe lift?
lift it any way you can lift?
body lift?
there is a section in the forum Called Lifting Tech <-- clicky, that is all about it
99blaz 02-26-2010 08:07 PM
Trailmaster and bds make a 5 in lift and superlift makes a 6 in lift. Gonna run ya about 1500-2000 though.
jimmy979 02-26-2010 08:12 PM
any lift.. was hoping to go 5 inch lift then maybe 2 inch body if i want to go 33s but cheaper the better thanks guys.
NVANZEE 02-26-2010 10:09 PM
need a better definition of cheap. When i think cheap, i think a few hundred bucks. If you want a 5-6in suspension lift it will be around 2k. A 2in body lift will be $200-250
jimmy979 02-26-2010 10:52 PM
Well i was planning on 5 inch Trailmaster or a few others i seen i kno there around 1500 to 2000 if anyone has a link where to find them cheaper, or is there a cheaper way to get a 5 inch lift.
ABN31B 02-27-2010 03:55 PM
Cheap and 5" lift dont really go together unless you get it used on craigslist or something....
Link gallery!
Link gallery!
Link gallery!
Link gallery!
jimmy979 02-27-2010 09:21 PM
Just wondering if 2 inch body and 2 inch shackles torsion keys with 31s would give me enuff clearence. And if i go 32 inch tires will they rub with the 4 inch lift.. i kno im going to have to get new shocks as my front end is sagging a bit but i think i might go with that kind of lift.. not shure having hard time making up my mind.. Somone told me that if i go 5 inch lift they break to often. is that also true
jimmy979 02-27-2010 09:31 PM
I found body lifts for 130 bucks and the torshion keys with shackles for around the same price.. all is going to be under 350. But was wondering if this would give me enuff clearence for trail riding.. and some mudding i kno stock hight just doesent cut it.
greenjimmy 02-27-2010 09:36 PM
hey man, u can trim ur fenders to clear bigger tires. there is a few guys on the s10forum running 2"bl2"sl with 31's 32's and 33's.the amount of trimming and ur backspacing determine what size u will run.
