looking for a lift
i have a 2000 4 door 2wd blazer im looking for a good 4'' or 5'' suspension lift... any suggestions?
i have a bds 5" lift kit in.
it went in pretty good...my only complaint is finish doesnt hold up well. but all in all...happy camper. |
did you ever fix that with the tack welds wart?
actually at the time and wind chill...i used double nuts to do the job.
with the nicer weather i will be looking for the better fix soon. |
ahh got ya I think the tack welds are the way togo with these kits
Ive seen many users of this kit do that |
Originally Posted by TURBO
(Post 505098)
i have a 2000 4 door 2wd blazer I'm looking for a good 4'' or 5'' suspension lift... any suggestions?
Turbo is looking for info on lifting his 2WD blazer. I think you guys are talking about a 4wd lift..
My son has a 2WD Jimmy. I installed the MOOG 2" coils and that brought the front up just above level with the rear. I just purchased 2000 s10 lift spindles and 2" lift shackles for the rear. Because the Jimmy is a dual piston caliper and the s10 is a single piston you have to use the s10 calipers and rotors. Luckily mine came with these parts. I will have to have a longer brake line made with s10 banjo on one end and Jimmy fitting on the hardline end as the s10 and jimmy lines are not interchangable, it will be @ $70 for the lines. I hope this helps you out Turbo |
