-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Is this to much of a t-bar crank (https://blazerforum.com/forum/lifting-tech-44/much-t-bar-crank-78718/)
bdemutis 04-19-2013 12:40 PM
1 Attachment(s)
I was wondering if this was to much of a torsion bar crank?
https://blazerforum.com/forum/attach...ine=1366393248
gitch93 04-19-2013 12:48 PM
nah thats nothing compared to mine lol. u will be fine to drive just make sure u keep on maitnence and grease the ball joints to keep them working right with the added angle
warthogdriver 04-19-2013 04:34 PM
how many turns did you do on each key?
watch the boots on the cv shafts...they can slip off and toss all the lube all over and if you let the joint go dry you will be getting a new one soon. did you measure before and after? "common" rule is to go 1.5" higher for a "safe" torsion bar lift.
bdemutis 04-19-2013 07:26 PM
No I didn't measure and a guy I know who works at advance said he usually cranks them all the way in and cranks them out 5 turns that's what I originally did. Do the CV angles look to severe?
bdemutis 04-19-2013 07:29 PM
Also I already need ball joints when I bought my blazer it needed them they were popping and when I t bar cranked the first time they stopped popping.
