4 Attachment(s)
So yesterday I took the rear axel of the Blazer to make way for my new lift kit and I'd like to go with a wider axel any suggestions?
Lifting my 2000 Blazer 6" now that the rear end is off it I'm thinking I want a wider one is there a wide axel that will bolt in? |
Just use spacers. Cheap, easy and proven!
If you want something wider try to find a zr2 axle. the only problem you'll run in to is the gearing will most likely be different so you'll need to regear your front differential.
And one post
Originally Posted by newguy
(Post 664420)
And one post
Thanks for pointing that out I missed it! It is now fixered:) |
