My Truck
Here it is, its a 1995 Blazer LT 4dr 4wd if you couldn't tell... lol. I baught her for $750 with brand new toyo open country a/t. It needed a pitman arm, idler arm, ball joints, front driveshaft seal, and a hub for the front right tire. Oh, can't forget the motor mount i have sitting on my back seat. Here she is stock.
http://i266.photobucket.com/albums/i...1/P2060253.jpg Here she is with the 2" PA Body lift. http://i266.photobucket.com/albums/i...1/P2280257.jpg I also have 2" shackles sitting here in front of me and plan on doing a tbar crank. Also my 33" Toyo Open Country M/T's that came today. They will be mounted on the Cragar Soft 8's that are sitting in my bedroom. http://i266.photobucket.com/albums/i...1/P2280258.jpg I am aware that i will need massive fender trimming. The truck is pretty much in ship shape other than a few minor things that are more pet peeves. my rear bumper is slightly bent for some odd reason, i have a patch of surface rust on my hood and on my driver side passenger door. In the future i would like to find some zr2 fender flares and hopefully find a way to make them fit. My final plan for now is to paint/rhinoline the frame rails soon. Watch out for updates on the shackle/tbar crank! thanks for looking.[/align] |
RE: My Truck
VERY nice! I love those Toyo M/Ts! I like the look with the body lift on too..makes it look much more truck like I think:)
Did you put on the BL yourself? Or pay a shop? |
RE: My Truck
33's are alot to put under there. You should look at Rcars2. He has pretty much the same setup.
RE: My Truck
Looks good!!! 33's shouldn't be to hard to fit.
RE: My Truck
ORIGINAL: WolfPack VERY nice! I love those Toyo M/Ts! I like the look with the body lift on too..makes it look much more truck like I think:) Did you put on the BL yourself? Or pay a shop? ORIGINAL: willjones 33's are alot to put under there. You should look at Rcars2. He has pretty much the same setup. ORIGINAL: Millertime21 Looks good!!! 33's shouldn't be to hard to fit. |
RE: My Truck
You will fit them with fender trimming in the front!! You don't have to trim alot just enough for turning and bumps!!!
RE: My Truck
ORIGINAL: thegr81 You will fit them with fender trimming in the front!! You don't have to trim alot just enough for turning and bumps!!! |
RE: My Truck
You might need to still trim your fenders.. Because when you got in reverse and turn the wheel you will hear the wheels rubbing on the fenders. I have a 6" lift with 32's and I had to modify my fenders a little.
RE: My Truck
cant wait to see it with the tires on it. I am still waiting to do a bd lift then get some tires. how did you like the open country A/ts. I hear a lot of good things about them and I am possibly going to look at getting a set of those.
RE: My Truck
nj4x4blaze, i know im going to be trimming alot lol.
jphayes the toyos are great, id recomend any toyo tire. |
| All times are GMT -5. The time now is 04:41 PM. |
