Need lifting help to clear 33's
I have a 2001 GMC Jimmy SLE 4x4.
I want to be able to clear 33" tires, 12.5" wide, on 14" rims while maintaing full flex and minimal to no tire rubbing.
Any suggestions...?
I understand with these vehicles you will most likely need to do a lot of extra moding, but what kind of moding will I be getting myself into? Choppin fenders is fine by me if I have to.
I was thinking a 3" body lift and a 6" suspension... I would consider myself a beginner off roader but I know how to handle my self on the trails fairly well. I just don't know a whole lot on the mechanical side of things...
Any help would be greatly appreciative and duely noted.
Thanks to all,
-Garrett
Any suggestions...?
Thanks to all,
-Garrett
In response to Warthogdriver; I was thinking it would take that to clear em as well. My plan was 3"bl and 6" suspension. Maybe with those 2 extra inches I wouldn't have to do much, if any trimming? Also with lifting it that high what other parts and tweaks did you have to do? extended drive lines, axles, etc. I would definitely replace all bushings and seal everything up.(I have independent suspension btw) As for the gears Tibby, like 4:33 ratio...? That's one side of things I have absoluetly no idea how to do without a shop... I also wanna be able to drive this daily.
Thanks for everyones input,
-Garrett
-Garrett
as far as lifting i had to do several things outside of just bolting on the lift.
my driveshaft had to be rebalanced..but length was fine
i added 6 degree shims to rear axle
rear stabilizers had to be lengthened
and i had camber issues...(that is fixed for now...i added a second nut to each bolt)
i had to trim front wheel wells slightly...i exp rub with big bumps/dips in road.
daily driving was fine.
with body lift you may want gap guards...up to you on that one.
the tires you want are almost the same as mine except i have 15" wheels.
now with you doing 6" i dont know about the driveshaft. there are a couple rides on here with a 6" lift...search and you should find them.
that is all i can think of right now.
I am not hard on my ride...i go offroad for pleasure cruise only.
i havent had any terrible wear issues...but i redid the whole suspension when i did the lift last year.
The camber issue is that i have trouble with the bolts slipping and letting camber out on the tires...THAT WILL CHEW TIRES!!! I am looking to fix it right very soon. From what i have found searching around the googleverse is that it seems like a somewhat common lift issue.
I think the amount of susp travel loosens up the bolts.
Not sure why you would want to go down to a 14in wheel but im not sure if they would clear the front brake calipers. With the 15s i have i had to use stick on wheel weights on the inside of the wheel and i cant get them to stay on cause they hit the calipers.
