| carlosblazer |
11-03-2011 04:33 PM |
new rough country 2" lift
Has anyone used , see or bought the new rough country lift for the s10 blazers/jimmy? is so much difference between the new one and the old one?, i have some questions, maybe you can help me decide if i bought it or not
1.- i have seen that it has new A-arms with integrated ball joints (what happens if the ball joint fails, is there a replace for it? but i think itīs way better to use it instead of crank the t-bars 2,5 inches.
2.- they drop the differential (you have to cut it) but the front diferential works at the correct angle
3.- the rear lift is practically the same but it drops the sway bar
i think it all helps with the wheel travel at the front and rear axles?
this kit as i se it has more pro's than against, maybe you can help me confirm this or give me your opinion, thanks a lot
