-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Rear block lift? (https://blazerforum.com/forum/lifting-tech-44/rear-block-lift-84156/)
hart5454 01-29-2014 10:14 PM
Rear block lift?
I am new to this forum and i want to lift my 95 4 door. i want to do torsion bar keys and a block lift on the rear. Has anyone done a block lift on this site? my concerns are that i will have to extend my brake lines and possibly other things. i have also done research on here with the torsion bar lift. i was planning on getting 1-3"torsion bar keys and then getting a set of zr2 torsion bars. can anyone help me with this?
rexmburns 01-29-2014 10:49 PM
If you put blocks in the rear you will lower it! Your truck is SUA look around and you will find just about every lift combination possible.
Diaita 01-30-2014 01:06 AM
Only options are an add-a-leaf, different springs, or a extended shackle to lift the rear. Or spring over, but that is about 5" of lift.
hart5454 01-30-2014 11:27 AM
Ok we'll then I am going to do shackles in the rear. But with the 1-3" torsion keys do I have to get new shocks that are longer or will stock be fine?
rexmburns 01-30-2014 12:02 PM
shocks are fine! You should really spend some time looking around the forum these questions have been answered may times:)
TStoddard 02-15-2014 06:01 AM
I'm contemplating a small lift on my 98 Jimmy 4x4 and picked up a set of blocks for the rear. Is it true you can use blocks to lift OR lower depending on where you place them?
newguy 02-15-2014 06:49 AM
Read above, blocks for lift, No
Steve-o 02-15-2014 07:37 AM
our blazers are SUA spring under axle, when you place the block between the axle and leafs on a SUA you'll intern raise the axle up into the body per say, thus lowering your blazer.
Diaita 02-15-2014 01:30 PM
This... :icon_nic:
hart5454 02-16-2014 09:56 AM
If any one on here tries to do a shackle lift you WILL need to get longer shocks! The stock will not work like people on this site have said previously!
