-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Rear lift (https://blazerforum.com/forum/lifting-tech-44/rear-lift-11134/)
sasquatchfound 06-06-2007 09:50 AM
Rear lift
I would like an opinion. I'm trying to deside on either shackles or a rear axle flip on the rear of my blazer. If i go with the axle flip the fab guys would make a custom traction kit to prevent axle wrap for under $160.00 for me. So which way should i go?
Jigg 06-06-2007 10:03 AM
RE: Rear lift
The axle flip will get you 4.25" of lift. What're you going to do to the front to match that?
sasquatchfound 06-06-2007 10:16 AM
RE: Rear lift
I plan on using drop brackets for all the nessisary components
Jigg 06-06-2007 10:19 AM
RE: Rear lift
You should just buy the Trailmaster or Superlift kit then. They include the kit to flip the rear axle, along with all the necessary brackets to lift the front.
sasquatchfound 06-06-2007 10:26 AM
RE: Rear lift
Thanks jigg i will have to check that one out
