-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Rough country 2.5" (https://blazerforum.com/forum/lifting-tech-44/rough-country-2-5-a-83741/)
01 Jimmy SLE 01-08-2014 09:01 PM
Rough country 2.5"
I've read a ton of reviews on here of this lift kit. Some good, some bad. For those with this kit (the newer one that includes the dif drop bracket), how well does the dif drop actually work? How much did it drop the dif? I know the kit tries to fix cv angles and upper ball joints, but what about the lower balljoints? Won't those be at a harsh angle and wear quickly? I don't plan on cranking the torsion keys to the max, but I do still want to gain some lift.
robsteez 01-12-2014 04:38 PM
I have had the lift kit in for 6 months now and the diff drop bracket does fix the cv angles. I didn't measure exactly but from looking at it it dropped the diff down 2.5-3 inches?. I did some pretty hard wheelin trips with it and had no problems with my ball joints surprisingly. The only issues I have had was I blew bolth my front n2.0 shocks after a month and the bolts for my diff bracket always come lose and fall out... I welded the plate to my diff.
01 Jimmy SLE 01-12-2014 11:16 PM
Thanks for the input! Did the shocks blow because they're junk in general or were there other factors? Like just a bad set of shocks or something?
Jamaroon 01-13-2014 06:47 AM
It doesn't drop the diff that much, it's around an inch.
robsteez 01-13-2014 07:12 AM
an inch? it looked like bracket had atleast 2'' more length then the stock...im trippin. As for the shocks I hit a pot hole on the passanger side wheelin and blew all the fluid out then a week later my driver side leaked out too... they might have been faulty
Jamaroon 01-13-2014 09:00 AM
maybe 2" at back, but nothing in the front so 1" at the center where it matters. same reason a shackle 2" longer than stock would only get you 1" of lift at the center of the wheel well.
Dolanjohn1990 07-29-2014 05:20 PM
So Im in the middle of this lift and I ran into a problem with the differential drop. I made all the necessary cuts and the steering linkage hits the dif. It makes it so I can not turn right? I know I didn't do this wrong. the other thing is when I crank the torsion bars I see no change in the control arms position. Do I need to hang the tires and put it on the ground to get some weight on the suspension before I try cranking the bars in order to see the change?
Jamaroon 07-30-2014 07:15 AM
You won't see the change until it's on the ground. As long as the bolt is moving then it's being adjusted.
Dolanjohn1990 08-15-2014 06:59 PM
Ok cars on the ground and the destructions said i should measure out 21" from wheel center to fenderwell. I have a 2" bodylift. Doesn't that mean i should be at 23"? Im still at 21". I crank the tbars and dont see or measure any change. Did i put the tbar back wrong? I didnt really think I could screw that up....
Jamaroon 08-15-2014 09:30 PM
Yes, you should be at 23" then. Did you have to use a torsion bar tool to get the bolt back in?
I think the ear of the torsion bar key was pointing down at about 4 o'clock, maybe a little more before forcing it into place with the tool and installing the bolt and block.
