-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Rough Country 2.5" Lift long-term satisfaction? (https://blazerforum.com/forum/lifting-tech-44/rough-country-2-5-lift-long-term-satisfaction-100787/)
Hadyss 09-22-2020 08:10 AM
Yes they use the full size truck ones
IslandBlazer 09-22-2020 07:51 PM
Score! okay then I have two of those in the RockAuto shopping cart...my next question is I'm going to get the high angle CV Joint installed but should I replace the LOWER ball joints as well since I will have the front end basically all apart? Are there recommendations for such a part?
Hadyss 09-22-2020 07:55 PM
get the mevotech ttx lowers too they also make wheel bearings now too
IslandBlazer 09-22-2020 08:04 PM
But since I'm not replacing the lower control arm with the RC kit, I would want to get a part made for the Blazer and not the Chevy 1500 correct? Or would I want the matching set? Can I ask for you to link the part in RockAuto again?
Hadyss 09-22-2020 08:13 PM
The front lowers if it’s the same across years. This is the one for a 2000 but I think it will work across years
https://cimg3.ibsrv.net/gimg/blazerf...3bed98b80d.png
IslandBlazer 09-22-2020 08:18 PM
Perfect. Thank you, friend. One day ill make a build thread and include all this info. You all have really helped me make some educated moves when doing this huge upgrade
IslandBlazer 09-22-2020 08:25 PM
And jut like that...Upper/lower ball joints, CV joint boot, and RC 2.5" lift to be delivered to my house next week. Ill update the thread at the next junction...if you wanna keep up with my build im gonna move somewhere into the wheels and tires section to get some good shoes for the truck.
Hadyss 09-22-2020 08:29 PM
I’m curious which will come first my rc lift came super quick but rockauto is super quick with shipment stoo
IslandBlazer 10-30-2020 02:52 AM
Originally Posted by Hadyss (Post 727429)
I used the mevotech ttx txk6540 ball joints for a 2000 Sierra 1500 they are the size used in the rough country control arms got them from rock auto and they are super strong I find the stronger then the moog
https://cimg4.ibsrv.net/gimg/blazerf...0fefe8ddb6.png
u will need a press kit to remove the old ones and install the new ones and there is a c-clip inside holding them In
Update: I was able to get the lift installed! But the upper ball joints were too small to fit inside the threads. The mechanic explained it to me as “ it’s too small, it just floats, the threads don’t grab anything.” I don’t know if RC changed the control arm but those ball joints did not fit. Not a problem though. I will be contacting RC to reference through them the ball joints that can fit.
But other than that the truck is amazing now!
christine_208 10-30-2020 09:53 AM
I suspect RC changed the ball joints they used sometime in the last few years.
