I'm in Birch Run-in the new control arms have a bit more angle and slight presses in the tubes for clearance. They aren't much different, the ball joints are just quality now. I didn't cut my diff. though. I had muffler man put it on but it was easy as cake to them.
what size tires are you runnin?
Originally Posted by chicagotyler
(Post 488011)
I plan to upgrade my rims to either Dick Cepek DC2's (if they'll fit correctly) or Procomp Streetlocks. I just dont know about the black yet. |
3 Attachment(s)
Look out. I might just have to go for ROTM.
After all of the time, money, research and work that i've put into this, I think that I will. It surpasses any fullsize in the mud and even my buddys 04 Silverado with SAS and a 14" lift. That says something right there. The ability for this to come to a complete stop in a trail and barely press the throttle and hook up is a wonder. I still dont understand it and have yet to become stuck. I very, very, very much so reccomend this setup. It will continue to get better. Thanks for watching. |
Great now I want something else for my truck that I can't afford. Looks awsome, is there any rubbing from the tires on full flex?
Originally Posted by DKSDAD
(Post 488310)
I wouln't waste my money on this kit... oh yea... I did.
Save your hard earned cash and simply do a torsion bar crank in front and shackles in the rear along with a body lift. The 2.5" "lift kit" with A-arms will only amplify the aggrevation of the front CV shaft angle issues at no greater ride height... lol. |
Originally Posted by bandidolenny
(Post 488452)
(Post 488497)
@Bandidolenny, did the kit you bought include the diff drop? Rough Country redesigned the kit to include a diff drop to keep the angles within factory specs allowing the lift without the bad CV shaft angles. The newer kit is way better than the old lift kit which was essentially just a T-bar lift with shackles for the rear.
http://i233.photobucket.com/albums/e...untryInfo2.jpg http://i233.photobucket.com/albums/e...ntryInfo-1.jpg |
If you must install a suspension lift then just spend real money on a real 6" lift from one of the major manufacturers. Just my 2 cents.
| All times are GMT -5. The time now is 04:32 AM. |
