Community
Search
Rough country?
Old 01-24-2019, 12:05 PM
christine_208 is on a distinguished road
Originally Posted by carlosblazer View Post
Do you have any additional problems assuming that you donīt drop the diff? considering itīs a 2,5" lift, maybe your differential is working on a critical angle, considering that the recomended lift doing the t-bar crank is 1" to 1,5".
Is this question for me? If so I can't say I've had any other issues although I'd recommend to anyone doing a T-bar crank lift that with all of the suspension work to be done on the front, it is a good time also to perform preventive maintenance service on the CV joints. I was a bit intimidated by them at first but actually it was not hard to disassemble the inner ones and replace the boots with new neoprene ones that are more flexible and refill them with fresh grease. After 15-20 years, it is worth doing to keep the joints in good working order if your axles still seem to be in good shape otherwise.
Old 01-24-2019, 02:24 PM
cleburne red's Avatar
What size lift did you get, OP? I have the rough country 6 inch lift on mine. It drops the diff down, but the.cv angle still isn't flat by any means.
While we're on the topic, are there any heavy duty, high angle cvs available for our trucks?
shadow03
14
07-23-2020 07:44 PM
Ian Seals
29
04-20-2019 05:14 PM
blazer37
05-04-2011 03:59 AM
extreme
Lifting Tech
28
03-02-2010 08:20 PM
jaredi1989
05-31-2008 08:08 PM
Quick Reply: Rough country?
