Sas but not too high
I'm thinking about doing a sas on my 91 but everytime I see a build it's jacked way up and I don't need something like that. All I've had were trucks with 3 in susp and body lifts and that always got by I assume if I don't use as many leaf springs the height will be lower. Please correct me if I'm wrong thanks
There are allot of variables that go into keeping a SAS low and more info of what you hope to accomplish is needed. Tire size plays a role in height as well as springs. Part of what you have to take into consideration is clearance for the front diff. To low and you will be hitting your oil pan or cross member. What are your intended uses for the truck. Check out km346's build for a perfect factory looking SAS. I know it's a second gen but it will give you a good idea of what it takes to keep it low.
Okay thanks. The intentions with it are off road it as much as my zr2 which was like 2 times a month. The three places I go aren't tough but the one spot is cursed I've always snapped a cv axle or both there. Tire size I was trying to stay 33 or less.
Just looked at his build while at work and that looks perfect thanks for informing me of his but I should've done a better job searching
No problem!. Check out all the builds here as well and especially the stickies!
4wd SFA - S-10 Forum |
I bet you could keep it fairly low, and have plenty of room for 33"s, you just gotta get out the sawzall and grinder and make some clearance in those fenders!
1 Attachment(s)
Originally Posted by cleburne red
(Post 637788)
i tried to keep my truck as low and wide as i could Attachment 30995 i used 6 inch k5 blazer lift springs up front with a few leafs removed axle flip and a 3 inch block in the back |
