shackle lift?
hey i was curiouse if anyone knew a place where i could get some decent, reasonably priced greasable 2inch lift rear shackles. got an extra 2 " out of cranking the t-bars now i want to level it out.
RE: shackle lift?
HERE is a set for $71... if the link doesnt work, you might have go to through and enter your truck info into it.
RE: shackle lift?
got a set from jackit.com for 80 shipped, but not greasable. I think they offer a set of greasable ones though.
RE: shackle lift?
Additionally you could make a set if you or someone you know can weld. Just need some flat stock, a welder, and a drill press and thats pretty much it.
RE: shackle lift?
i bought a good set for $20 at Murray's. they arent the best in the world, but i put 31's on for winter and needed some lift. i got about 2 inches out of them :)
RE: shackle lift?
o yea i know how to weld, ive only got a lil 70 amp ac at home so it wont do the job, plus i was thinking i would stick with greasable shackles. is there a good advantage to them? if not i have a fewplaces where i can go use a welder. i welded brackets to mount a brush gaurd on the front of my 2000 blazer, a gaurd off of a nissan. and i think the brackets hold better than any stock one would.
