Originally Posted by coolasice
(Post 564172)
a ball joint press will pop those babies out no problem...
What about the heat and wax trick?
i ended up saw alling the bolts off then using a method found here on this site, using a drill bit and drilling out the rubber from the bushing, then removing the old bushing and replacing the bolt and nut, its a PITA, but i sure do like the new urethane bushings, i also coated every thing well in grease, so the problem wont happen again..
Originally Posted by neo71665
(Post 564180)
Now that I own one that's the only way to do it. Not everybody is as well stocked with tools. When their DD/only ride is tore down sitting in the yard at a stuck point suggesting a tool they don't have and can't go get is like pouring salt in an open wound.
