-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   steering stablizer (https://blazerforum.com/forum/lifting-tech-44/steering-stablizer-58183/)
sharrard. Apr 20, 2011 11:43 AM
steering stablizer
do i need a steering stabilizer for a two inch suspension lift?
nismo_2005 Apr 20, 2011 07:37 PM
No you will be fine without one
nj4x4blaze Apr 20, 2011 07:45 PM
^what he said^
pbrubaker12 Apr 21, 2011 11:37 AM
I bought one anyway on my 2" susp and noticed a pretty decent difference...
IMO it helped a lot and the feel is awesome but that's just me
Rottidog Apr 21, 2011 12:17 PM
I went from stock 235's to 32" x 11" on 10" rims & found I need to add a stabilizer on the front because a few potholes or uneven roads & the truck wants to FO in it's own direction lol. Yes it's aligned, just that the tires are a bit much for the stock steering.
atvwarrior Apr 21, 2011 01:48 PM
In order to mount the stablizer shock on a vehicle that didnt come with one stock you have to get a center link that has the hole for it , Right ?
s14sh3r Apr 21, 2011 02:08 PM
They make kits that bolt on using u-bolts.
Rottidog Apr 22, 2011 10:13 AM
Or weld on brackets, they may have them or fab one up. You have to measure the travel that you'll need in the stabilizer or you'll cut your turning radious down because the shock (stabilizer) will bottom out at compression or extension.
