Super 10 radius arm questions
I am a Jeep guy. That has owned a ZR2 Blazer since new, its a 2001. So I am looking at the Super 10. If I do this I would search out an XJ HP30 with 3.73 gearing, and do a spring over in the rear. I do know that they say the spring lift for the xj coils is what it will lift the Blazer. Here goes my questions.
When I swap the axle in, it looks as though I can use the y link from the axle with a special pitman arm is that true? Can I use an aftermarket adjustable trackbar for the XJ or the TJ, they are the same anyway. I have not been able to locate the adapter plate that allows the use of the Blazer hub on the Jeep axle. I also heard that my autotrak tcase is very similar to the Jeep 231 and can use the same SYE for it, is that true? I heard also that I can find stock shafts from other vehicles that will bolt right in with double cardons front and rear, what models do I look for? |
