torsion bar
I have a ? about lifting my 98 blazer i know how to lift the rear easy but i just dont know an easy way to lift the front of my blazer... i want to go for at least a couple inches, but is tightening the torsion bars the only way to lift the front???? thanks!!!!
RE: torsion bar
If youre using shackles in the back then yes. you could always go with a body lift kit from performance accessories (frame spacers).It would take more effort/money to do but it wont wear out your front end as much as cranking your t bar.
RE: torsion bar
The other option is to get new torsion keys, that way you don't have to crank as much as your ride stays smoother.
RE: torsion bar
Keys just relocate the point which the adjustment bolt hits. It does not correct anything with how "wound" the torsion bars are or any of the ride harshness as those things are only changed by moving parts around on the other end ($$$).
