Torsion Bar Crank Tutorial
Old Jan 15, 2008 | 09:33 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default Torsion Bar Crank Tutorial
Moved to the Tech Article (DIY) section:
How-To: T-bar Crank
Merged Discussion from this thread into:
How-To: T-bar Crank - DISCUSSION
Old Nov 18, 2009 | 10:52 AM
odfareal's Avatar
odfareal is on a distinguished road
Links in thread appear dead.
Old Nov 18, 2009 | 11:00 AM
The link to the Article was in fact dead, but the lower one worked. It is now fixed.
Old Jan 5, 2010 | 04:09 PM
BIGDAVEEVADGIB's Avatar
BIGDAVEEVADGIB is on a distinguished road
when you crank the tortion bar how much wear dose it put on the u joints and how is the ride
Old Jan 5, 2010 | 05:31 PM
I doubt you will ever find a number associated with how much more wear occurs after a t-bar lift. There are just too many contributing factors to actually quantify it.
As far as how it will ride, it will definitely be more truck like.
Old Jan 5, 2010 | 06:03 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i talked to a master tech about this and he said as long as a front end alignment is done after the t-bar crank you should not have any problems. i imagine wear is still gonna increase.
Old Jan 5, 2010 | 07:23 PM
It will most definitely be harder on your ball joints and CV shafts.
Old Jan 5, 2010 | 07:33 PM
Banned
a front end alignment would help out a little though right?
Old Jan 5, 2010 | 07:39 PM
It would help keep your tires from wearing out faster, yes. It will not correct for the angle change though and the angle change is what will accelerate the wear on the ball joints and CV shafts.
Old Jan 5, 2010 | 07:44 PM
Banned
alright.
