-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Torsion bar Lift (https://blazerforum.com/forum/lifting-tech-44/torsion-bar-lift-45433/)
greatwhite 06-06-2010 07:04 PM
Torsion bar Lift
Ok I know this question has probaly been asked before, but I couldnt find the answers I was looking for.
Is a torsion bar lift work good? Do I also need to lift the rear? What is the purpose is it just to give more clearance for larger tires? Some have told me they lift the vechile this way for plowing why?
I want to just lift mine so I can put 31 on it with out having to do much trimming.
AJBert 06-06-2010 08:10 PM
All of your questions have been answered on here with perhaps one exception:
The reason to lift the front end using the tbars when using a plow is to compensate for the additional weight.
A quick search or even just a quick look under the same section as you posted this in will have the other answers to your questions.
And welcome to the forum!
nj4x4blaze 06-06-2010 08:12 PM
Yea what he said. lol
bandidolenny 06-06-2010 08:15 PM
Many people lift the front slightly and do not lift the rear in order to level out the vehicle and get rid of the nose down look.
Benedict1337 06-06-2010 09:21 PM
just search tbar crank and shackle lift there are tons of threads with everything you need to know
ImScrewed92 06-07-2010 12:53 AM
Alright let's break it down...
Is it a good thing? Yeah, as long as it's done right (IE in moderation.) Don't turn the adjuster bolts untill they bottom out, this will throw your suspension allignment out of whack. If you adjust the torsion bolts, just keep an eye on your cv boots, ball joints, etc. Also keep an eye on your tires, both tread wear and that they arn't leaning (out of alignment).
Do I need to lift the rear? Only if you want to keep a nose down factory look like most people have already mentioned. If you crank 1.5 inch (which is the general concensus as the limit), and you want to lift the rear a pinch. You can look up add-a-leafs and leaf spring shackles. The torsion bolts will only lift the front.
What is the purpose? Well agian like others have said it is used to compensate for added weight in the front, such as a plow, grille guard, etc. Also as the years go on the torsion bars may start to sag like any other form of spring. Thus the adjuster bolts which will allow you to lift the rear back up to stock. But for the most part it's just part of the IFS design.
With leaf springs and coil springs, when they wear out they can just be swapped out for new springs. Since torsion bars are not meant to truely be replaced. They incorporate the adjustment system of the indexed keys for height adjustment.
THE END, lol. Sorry for the book. Just thought I'd elaborate some.
greatwhite 06-07-2010 05:55 AM
Thanks ImScrewed92. That is what I was looking for so I will probably do it in a few weeks.
Blazin4x4trailz 03-26-2012 12:49 AM
Thanks man. I really want to add a lift to my 1993 blazer. Been looking it up and found most of my questions answered by you. Hope to get it done with in the next two months. Ill post pics of the whole prject.
Vegaas315 04-25-2012 07:55 PM
Help
I figured I would post on this because it was the most recent post that involved leaf springs. I cant figure out how to start my own thread. I know there is a "new thread" button but cant find it. :icon_doh: I am trying to find the stock ride height for a 1993 s10 Blazer 4x4. I can do all the adding and subtracting for my lift and tires, but I cant tell if they leafs need to be replaced or if they would do well with just an AAL. Need to find out if it is sagging too much. Both sides are about equal in height less than a 1/4 inch off from drivers side to passanger side. Well hopedfully no one shoots me for hi-jacking this thread. :icon_hunter::icon_hijack:
Thanks
airwak 04-29-2012 03:02 PM
EDIT: Lots of searching found my answer. Only need torsion bar keys if my torsion bars are worn out, if not then cranking is all I need.
