where to get shackles
ive been reading for hours on here and i cant find where people are getting the longer shackles... the links ive found are to old and expired ebay... thanks for the help!!
Google or eBay search they are really easy to find and they are interchangeable between all years:)
ok thanks... i didnt know how interchangable they were... i have a stock 98 4 dr lt 4x4... gona replace the tired tbars, new shackles in back, and i guess run 265/70/15,s or 30x9.5x15 (i dont know the difference)...
2 inch wide by 3/8th thick bar stock. Drill with 7/16th bit and hacksaw, grinder if you want pretty. Factory shackle is 4 inches hole to hole if I remember right. Add 2 inches to that for every 1 inch of lift. EX 6 inch center hole to center hole is 1 inch lift shackle, 8 inch c-c is 2 inch lift shackle (if I was right on factory measurement so double check).
If you are in canada I have a set of RC's kicking around. PITA to send south, you'll be cheaper buying some off ebay.
thanks guys!!
